Passing Clipboard text to the reader.
Does your API support passing text to the reader (Language Reactor) via a query string?
E.g. Language Reactor
I’d like to have a button for my readers/students to open the text in the reader with one-click.
Right-now they have to manually clear the existing text and paste in the new text after the window opens.
A button in the reader that clears the current text and pastes from the clipboard would also be nice.
This isn’t possible at the moment, thanks for the suggestions. We are planning to add support for text saving and shareable playlists in the near future.
Shareable playlists sound great.
I know the extension make it easy to import texts, but most of my students are using mobile devices. Having to highlight, delete, and then paste the text in is a bit clunky on mobile devices.
Keep up the great work. I recommend the extension to all my students and love that mobile support is getting better.
