Is there any way so I can know the percentage of already known vocabulary of the subtitles of an episode in netflix?
Thanks for your help ![]()
I’m not sure if this information is easily accessible elsewhere, but there is a way to calculate a rough estimate.
In a video, open the side panel:
Next, select “words” at the top, and you’ll see a list of all the words in the video:
To find the total number of words in the video, add up the values in the bottom row.
For my case, I used very few tags:
690+1+8=699
If you have any words marked as “Don’t Learn,” subtract those:
699−244=455
To calculate a percentage, divide the number of words you know by the total number of words:
322/455=0.708, which means about 70% of the words are known in this example.
The only issue I see here, is words that are considered “Don’t Learn” may also include words that are not recommended - which will skew the results, which is why I consider this a rough estimate - so it may be better just to keep those included, I really don’t know what would be best here.
Showing a percentage or known words would ben an excellent Feature Request, which can be requested here: Language Reactor Feedback
Thanks for the answer. When I select “words”, there is a message saying that this function is not available in the language I’m studying.
I guess that would be my first request.
Thank you for the information.
