The Reader Mode is excellent for Korean, but it would be great if it was possible to:
- Use Google Translate for the Audio: the voice that reads the Korean text is super fast
- Failing that, it would be good to be able to select the original text (this will allow the Google Translate extension to kick in for audio). Currently, I can’t select and the Korean text on the left hand side.
Thanks!
