Dear Language Reactor Team,
First off, I just want to say how much I love Language Reactor! It’s an incredible tool that has completely changed how I approach language learning, and I truly appreciate all the work you’ve put into it.
I recently started using it for Malay, but I noticed that the “Words” tab isn’t supported for this language. Instead, I see the message: “This feature is not supported for this language currently.” Since Indonesian is already supported, and the two languages have significant overlap, I was wondering if you could consider enabling it for Malay as well.
This feature is crucial for effective vocabulary building, and its absence is one of the main reasons I haven’t subscribed to the pro version yet. I believe many other Malay learners would also benefit greatly from this addition.
Would you be open to adding support for Malay in the near future? I’d love to hear your thoughts!
Thanks again for all your hard work. Looking forward to your response.
Best regards,
Hazim
