Currently when I import to Anki the English is in the front and the other language is in the back. That might be helpful to some ppl, but is it possible to have the reverse as well where the english is in the back?
What language are the words that you are saving? If they’re in english that’s how it the common template used around here is designed to work. If not, I do like the template that is floating around. I can maybe link it if you cant find it.
