When I click open the sidebar on netflix in Chrome, there is nothing there, just an empty space. Any clue why this is? I was going to purchase pro but if I can’t see my saved items it seems useless
Hello. What OS and browser are you using? Do you have any additional extensions installed and could you try disabling them?
I have the same problem, my guess is that the plugin does not support RTL. it is for sure an RTL problem, Please make user to support RTL, also settings list should be RTL.
