Translation Bug on Text Importer
Hello language nerds :slight_smile: ,
I am writing this to report a bug which I encountered
When I imported text, translation didn’t work properly.
I don’t know how I can solve but it is a big problem for me because after I import all my words into Anki, context translation is always seen same as the context language.
I solved the problem with prompting to GPT:
Prompt:
The following text contains irregular line breaks and inconsistent punctuation. Please rewrite it as a single, well-structured paragraph with correct punctuation and capitalisation. Return only the corrected text, and write “Text:” at the beginning of your answer, followed by the improved version.
