Why doesn't my sidebar work?
Why doesn’t my sidebar work?
What should I do about it?
为什么我的侧边栏显示不出来了,应该怎么处理呢,大佬捞捞
I have the same problem and I don’t know how to fix it :frowning: Side subtitles list is absents in fullscreen mode on YT
I will try to reinstall chrome and extension but it doesn’t help
I have this problem too. It only showed up today.
I have the same issue. Seems to be a website that language reactor uses, is down.
Access to fetch at ‘https://lb.dioco.io/mmd_YT_0’ from origin ‘chrome-extension://hoombieeljmmljlkjmnheibnpciblicm’ has been blocked by CORS policy: Response to preflight request doesn’t pass access control check: It does not have HTTP ok status.
Context
_generated_background_page.html
Stack Trace
  • _generated_background_page.html:0 (anonymous function)
So I don’t think reinstalling will help. We will probably just have to wait and see if the website comes back up.
thanks,then i will have to wait honestly
same i hope the devs fix it asap
In my case subtitles start working in normal mode, but in fullscreen mode it absent
It was some CSS change on YouTube, seems. Should be fixed now. Please let me know if you still have any problems.
everything is ok, yet, thx)
