Anki export.
Hi.
LR exports only audio for Swedish. I need Enlish audio as well.
In Anki when I use TTS plugin to add Eng audio , I can select use from the “text”(“front”) or from the “back” side of the card. LR exports both languages on one “text” side and adds audio for swedish.
Is it possible to import to Anki to Cloze “Text” side only Swedish and leave english on the “Back” side?
So TTS plugin will easily identify what to voice.
Now “text” and “back” are in one
. Can you split them? So that I could use TTS properly. If I use TTS for English+Swedish it sometimes fails with searching for the language.
Thanks!
WBR,Dimitri
