I’ve been using the app for years and I really love it. Recently, some kind of subtitle feature has been integrated, and since then there are two black bars on the video, it starts playing twice, and the text doesn’t appear on the side. I’m unable to send you a screenshot. I’m at a loss. I would appreciate your help
Hello @gabor_buday,
Thank you for your message.
It is possible that another browser extension is interfering with the display of subtitles in Language Reactor. Please try the following steps:
- Disable all other browser extensions except Language Reactor.
- Refresh the video page and check if the problem persists.
If everything works without other extensions, enable them one by one to determine which one is causing the conflict.
This will help us determine whether the problem is caused by a conflict between extensions or something else.
Thank you for your help! ![]()
