Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: en, tt_key: SUBS_en_1_574168d31dc7f239632217e2d2e71cc4
Are you still having issues?
As a user of LR of noticed this happens/can happen off and on due to various potential server status issues (it’s over heated/overloaded), but usually clears up after a period of time).
I’d check in on the extension periodically and see if it ends up being able to retrieve the data at that time.
I hope this clears up soon and you can get back to using LR! ![]()
Thanks for the advice
