I’m writing to suggest an improvement that I think would be extremely valuable for Language Reactor, especially when exporting cards to Anki.
The AI-generated explanations that appear when clicking on a word are excellent. They are very clear, highly contextualized within the sentence, and do a great job explaining the exact meaning and nuances of the word in context. In my opinion, this is one of Language Reactor’s strongest features.
However, when exporting cards (key export → Anki), these AI explanations are not included in the Anki card, and there is currently no option to add them automatically. This is quite unfortunate, as these explanations have very high pedagogical value and would be extremely useful during Anki reviews.
It would be extremely helpful to have an export option that allows the AI explanation associated with each word to be included directly in the Anki note (for example, in a dedicated field). From a technical perspective, this seems like a relatively simple feature to implement while providing a significant benefit for users who rely on Anki for spaced repetition.
Thank you very much for your work on Language Reactor, which I use daily, and for taking the time to consider this suggestion.
Best regards,
Ary
