I would like to request an improvement related to how flashcards are generated and exported to Anki.
My main goal is to use Language Reactor to mine vocabulary and then study it in Anki using the Refold deck format. I am not requesting new learning methods or extra features—only that the exported flashcards follow the same structure used by Refold decks.
The idea is:
- Use Language Reactor only for mining words and sentences
- Export them to Anki
- Study them using the Refold-style card structure
To make this clearer, I will attach a sample Anki deck that already uses the Refold format, so you can see exactly the structure I would like to use when practicing.
Link: https://drive.google.com/file/d/1OR48gyQjzQv52oB4xmNH-sikYiNoWyq8/view?usp=sharing
In short:
- Same Refold card structure
- No changes to learning philosophy
- Just compatibility with Refold-style Anki cards
Thank you for considering this request. I believe this would be very useful for learners who already follow the Refold method and want to integrate Language Reactor into their workflow.
Best regards.
