im not tech savvy in the slightest. Ive got a macbook air 2015 and I’m using google chrome to play netflix, Ive allowed language reactor whenever it is requested. But i cannot for the life of me get language reactor to work on netflix. everytime i click on the app in my toolbar it just brings me to the language reactor page, but it doesnt do anything to netflix
my chrome says that the language reactor page is not secure, ive allowed it but it still seems that this is causing a problem
Same!!! I cant use language reactor at all ==
Hi, to use the features of the app on Netflix, you don’t need to click on the app in your browser toolbar. Instead, you should go to Netflix and click on a movie like normal. Then, in the video controls you’ll see the Language Reactor icon:
[https://i.imgur.com/f0hmhnQ.png](Netflix controls with LR icon showing disabled functionality)
You can click on that icon to enable the Language Reactor functionality. It will look like this after you enable it:
[https://i.imgur.com/FaFSYs8.png](Netflix controls with LR icon showing enabled functionality)
The procedure is the same when using on YouTube.
Hi, thank you for the reply, I understand what you are saying I should rephrase my query, I went to pressing the icon in my bookmarks because the language learning icon isn’t showing up on my Netflix app.
I mean webpage, not app.
