I am trying to use Netflix in the United States and using Language Reactor to translate Korean into English. Language Reactor has worked great for a few months but all of the sudden, the little switch in the lower left of the video that says LR is grayed out and when I click it, nothing happens. It seems Language Reactor has been forcibly turned off and nothing I do fixes it. I restarted Chrome, made sure all permissions are enabled, disabled and re-enabled LR in the extensions menu, uninstalled and re-installed LR and restarted my computer. Nothing has fixed this. I tested YouTube and it’s the same situation there. No matter the site, no matter what I do, Language Reactor will not turn on. What do I do?
Related topics
| Language Reactor not working | 3 | 4623 | October 14, 2025 | |
| Chrome updated and YouTube stopped working | 14 | 1778 | October 31, 2024 | |
| going crazy language reactor netflix not working | 5 | 1484 | November 25, 2021 | |
| Language Reactor dosen't work on my chrome | 0 | 608 | March 15, 2022 | |
| [SOLVED] Language reactor not working on youtube (on/off button wont turn on) | 26 | 6295 | October 4, 2023 |
