Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: ja
Same problem here. It seems to be happening from time to time. It is getting annoying.
Same problem over here. I would like to have a good service after paying a product…
I’m also experiencing this problem regularly. I have tried with different computers, web browsers and internet connections and still get this error.
There are many threads about it on the forum, and it’s been around for quite a while now.
It would be great to get some feedback from the developers. Is it something you’re working on, and do you have any idea when it might be fixed?
I have also been facing this for weeks now. Only happens on selecting ASR PRO GERMAN subtitles for me.
“Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: de”
It happens when I select the ASR PRO GERMAN subtitles as I am trying to learn German while being aware of English.
Same problem for over a month now. The extension is pointless if it works only a couple times a month…
Guys, I found the solution!!! Is not a definitive one but it works, I tried it on YouTube you can try it on Netflix if you want. Basically, all you need to do is reload the page, reload it many times. At first, it seems like is useless, you´re going to see the same error again, but I swear after many times of attempting it is finally going to work again, at least 1 out of 10 page reloads it´s going to succeed. Btw, if it doesn´t work not even once, restart your computer and try again.
same, please fix the issue!!!
Developers, have you seen this problem? Is this something you can solve? Could we get an update?
Same issue for NL language. Extension reinstall didn’t help
Idem pour ma part, j’espère que cela sera bien tôt résolu…
Pour info, j’ai utilisé un autre profil et ça a fonctionné. J’ai rebasculé sur mon profil habituel et cela a fonctionné 1 ou 2 épisodes aujourd’hui. Mais de nouveau “failed to retrieve linguistic data”. En utilisant un autre profil cela fonctionne encore, mais pas sur mon profil habituel.
Thanks, that’s really useful! I’ll paste google translation so everyone understand: For your information, I used a different profile and it worked. I switched back to my usual profile and it worked for one or two episodes today. But now I’m getting the “failed to retrieve linguistic data” error again. Using a different profile still works, but not on my usual one.
They are working on the problem, I hope it will be solved soon.
See Developers: Could We Get a Status Report? - #7 by Angelina_Kalinichenk
