Also having the issue
+1
error key: SUBS_en_228a1b80f6eaf58c81b25445dbda40c5
[Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR]
pinyin for chinese subtitles was working perfectly then stopped working. The normal chinese subtitles continued to work. . A “failed to retrieve linguistic data“error message was showing. I can now only see the normal chinese subtitles (which I don“t read) but without the pinyin which usually accompanies the normal chinese script.
I have this and also I canāt save words.
Im having this error now: Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: de, tt_key: SUBS_de_1_4845b8bd6b0d9c50010a0fb9df321db2
also having this problem error, canāt save words.
I have same problem.I reset the pc but still same.
I have same problem now. Language Reactor show the almost same error message. I canāt use it.
Back to normal for me! ![]()
And for me as well!
Thank you to the LR Team! for the quick response to this language-learning emergency! ![]()
Yeah, it got better for a while today, but now the same problem is happening againā¦
hello, iām from south korea⦠and same problem have been happened from yesterday
anyways i really love this app ![]()
I have the same problem and itās not back to normal for me so far. I can also confirm that the pinyin transliteration for chinese subtitles is not working at the moment. But I also want to say thank you for this great extension. I use it regularly for a lot of languages.
Also getting a similar error from Australia:
Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: zh-CN, tt_key: SUBS_zh-CN_1_2cddca5d261af5851fad0ec6ab5b757c
EDIT: Seems to be working now
it works fine now! - South Korea
It seems to be fixed for me too ![]()
try refresh the browser
Running into this again, anyone else?
