Language Reactor stuck on "Loading subtitles..." on Netflix
I’m a Language Reactor Pro subscriber and I’m experiencing an issue with Netflix.
Everything was working earlier today, but now Language Reactor is stuck on “Loading subtitles…” and never loads.
The settings also remain on:
Original language: **Loading…*Netflix audio language: **Loading… Netflix subtitle language: Loading…
I have already tried:
  • Reinstalling the extension.
  • Restarting Chrome.
  • Using Incognito mode.
  • Logging out and back in.
  • Checking that Netflix subtitles are enabled (Spanish audio + Spanish subtitles).
Nothing has fixed the issue.
I’m using:
  • MacBook Pro
  • Google Chrome
  • Language Reactor Pro
    Could you please help me determine whether this is a known issue or if there is anything else I can try?
Thank you very much!
It seems like quite a few of us are having the same problem. I am crossing my fingers that this will be over by tomorrow. In the meantime you can try FluentAI.
