I want to read the subtitles without having the translations on the side of them (after clicking print button). Any way to get that page to only show original subtitles?
I had the same problem. They’re adding features without the ability to turn them off. I found a workaround by changing to the translation language to something that’s not available, like Urdu or something, and then refresh the page. That’ll let you print it without the extra column of translations.
I will give that a shot when i get back home! I appreciate your reply. Thank you.
It worked perfectly! Thanks a lot!
A workaround is to Crtl+A the printed page, paste it in Excel/Google Sheets, and delete the translation column. Only takes a few seconds!
