Saving words
I don’t know how to do [make saved words from video show up on saved items page]
I upgraded to pro saved items page says “0” even though I have saved multiple words and phrases on a youtube video.
Did you check the Language set on the same language of the Saved words?
Yes, it’s set to my learning language.
If i well understand, you saved words (by marking them green/orange) on youtube’s videos but when you’re looking on the LR website, it doesn’t appear on the “marked words” ?
Did you saved the word before having a “pro” account and now that you have a “pro” account, the words that you saved aren’t appear ? If so, is it only on youtube video ? Also on Netflix ? Was it the same email address that you used when you had the free account and the “pro” account ?
Thanks for your answer
Good day
Can you send me the email address you signed up with?
If you don’t want to write it here, you can send it to me in a private message or thru Email: languagelearningextension@gmail.com
Yes, I think the words I saved were from before I upgraded to the pro account, But it took some time to work after I upgreaded. Now it seems toi be working ok. Thanks for responding.
