Search for a word and directly access the sentence
I really feel that a missing feature is the ability to search for a word and directly access the sentence containing that word in a video from the YouTube or Netflix catalog, which a site like https://youglish.com/ allows for example, Thanks.
Hello @laurent,
We have this feature, it works for YouTube, Netflix, and the books and podcasts section.
In the Saved section, you should click on the Source column to go to the desired fragment
Thanks for your reply but I think it’s not the same functionality, LR shows the source of the saved items which is good but what I was talking about is having a search engine that would look in all the LR database of subtitles and that would display the list of fragments or like the Youglish system that jumps directly to the first fragment linked to the search and that allows you to jump to the following ones easily. You should try on youglish maybe I’m not very clear :slight_smile:
Completely agree with you, it would be nice to have this feature, as in youglish.
