Trying to watch french and japanese shows from Ireland, was working perfectly until today.
Now it’s stuck on “Loading subtitles, please wait”
I’m having the same problem.
Same here for me. I’ve been having that problem with a few other shows too, that have Japanese subtitles for sure.
i have the same problem. js console is saying the following, not sure if related:
My netflix extension no longer works. It is infinitely -loading subtitles- , i have language reactor pro
Hello !
This problem can be from Netflix and not the extension. Did you check this conversation (it looks like it was the same issue (i also got. it in february, but fixed it with the link)) :
Don’t forget to tell me if it’s working after that or not !
Thanks
Nope, still having the same problem!
Here my answer to others users having the same issue:
Thanks to answer to my message
Hey,
It came. back for me, can you try on your side ?
Yes, it did! Hopefully it’s stable enough now!
I was trying to watch some new French Netflix new release from France few days back and was having the issue of loading subs… so I was frustrated and closed Netflix. Just now I opened and finally it is working well as of now. I hope it stays like this for quite a while now. How is on your side.
Hi Arthur,
No issue on my side recently, and don’t forget if you have the issue with loading sub, it can come from the netflix setting where you need to uncheck the “test” option.
Thanks
sociology,well.that’t right!
