The existing phrase functionality simply retains sentences without specifically preserving dedicated phrases, and there are also no phrase examples available
现有的短语功能只是简单地保留了句子,并没有针对专门的短语进行保留,而且也没有短语例句可提供。翻译这段话
I think probably LR can do what you want, but our instructions are not good at the moment.
Phrases are saved with the little star:
Try these options on phrasepump:
Saved phrases are listed under this tab:
I’ll work on some videos next to show how to use the saving system better.
Thank you for your reply. I understand what you said about saving the entire sentence. But that’s not what I want. I just want to save PHRASAL VERBS, not the whole sentence.
I also think this feature is very helpful for my studies.
For instance, it would be great if important phrasal verbs or collocations (e.g., end up, figure out, neither…nor) could be manual highlighted in bold or color so learners can spot them easily.
Thanks!
