I’m not sure if this is already possible, I haven’t come across a setting for it.
Sometimes there are certain 2/3/4 word phrases within a full sentence that I would love to save to anki on their own, without having to save the entire sentence.
We can click on individual words to bring up the translation, so maybe the ability to click and drag the cursor to highlight more than one word would come in handy for everyone.
Loving the app so far though, thanks for making this. I never knew studying movies sentence by sentence could be so addictive
Hi! I’d like to add my vote for this feature. Having the ability to save multiple words in a single entry would be very useful. A big aspect of language learning is developing the ability to “chunk”. LingQ solved this problem by allowing the user to drag the mouse over multiple words to select them, but there might be other ways to achieve this.
Right now I’m using the color system as a way to save phrases, but it’s not great.
Hi developers, please update this feature. It’s extremally helpful for language learning.
For example, in the sentence “I take off my shoes before getting into my house,” when we click on the word “take,” beside the usual dictionary, a pop-up should appear that includes the options “take,” “take off,” and “whole sentence” for us to choose from.
I’m really hoping to see a feature that lets me drag to select and mark multiple words at once. Right now I can only tag one single word each time. I’ve noticed the tool sometimes detects full phrases automatically, but I wish I could manually choose to save just that selected phrase instead of the entire subtitle sentence.
This would fix the messy issue when importing sentences into Anki—subtitles are often fragmented and incomplete, which makes memorizing phrases via Anki really cumbersome.
I’d really appreciate you considering and rolling out this function as soon as possible. I’m a newly subscribed paying user and absolutely love your product.
Hello @yu_Yu, thank you for your message!
One temporary solution I can suggest right now is to manually add the phrases you need to the “Saved Phrases” section. Here’s how to do it:
Copy the desired phrase from the subtitles
Paste the copied phrase into the dictionary popup
Save the phrase you found along with its translation
The saved phrase will appear in the “Saved phrases” section
This is a temporary solution that may be a bit inconvenient at times, but it solves the issue.
