ABOUT MEDIA_FILE_ PLAYER _v2.0 AND MKV FILES ARE NOT SELECTABLE
@David_Wilkinson
First of all, thank you for the new update on the video player, MEDIA_FILE_PLAYER_v2.0. The new features and improvements are greatly appreciated.
I am writing to report an issue I’ve encountered with the new version. While using the player to watch Japanese anime with local media files, I noticed that I am no longer able to select and play .mkv video files. The player only seems to be able to access .mp4 files.
This is a change from the previous version, which allowed me to seamlessly play local .mkv files. It would be extremely helpful if support for the .mkv format could be re-enabled for local media playback.
Thanks a lot in advance for your support!
Best regards,
Chris Lee
Hello @Fisher_County,
The .mkv format should be supported. This is a bug. We are currently looking into it. Thanks for report!
Thank you for the quick reply and for looking into this. Your program is a huge help for my Japanese studies!I’m really looking forward to the update! :smiley:
