Media File : Audio Track selector not working
Hello, in the new media file player, I tried with a MKV containing 2 audio track : one french and one japanese.
They both show up on the UI
But once the file is playing, the one I selected does not seem to work at all, and it’s only the default one (the first one, the french in this case) that is playing.
In the past I was changing them manually in the console doing
var video=document.getElementById(“plyr_video”);
video.audioTracks[1].enabled = true;
But even doing so, it seems only the first audioTracks (the 0 in this case) is playing
For info I tried again today and I still have the issue
Hello @Sound,
Thank you for your request. It has been sent to the team and has already been fixed. It will be released in the next batch. I think within a month
Great ! Thank you for the update. Is there any feed/mailing list to get info when a new release containing those fixes are pushed ?
@Sound We announce certain releases here on the forum in a separate thread (usually releases with new features).
If these are bug fixes, we announce them in a specific thread
I’m facing the same issue,; I selected track 2 (arabic) but instead it’s the first track thats playing. Same file extension as the OP. And can you link the bug fix thread? I cant find it. Thanks
Hello @Kronks
This will be fixed in the next release
Hello. It’s been 4 days. When will the issue be fixed and can you link the thread you mentioned [quote=“Angelina_Kalinichenk, post:5, topic:34341”]
[/quote]
