Thank you for making a good app.
I’m writing it down here because I’ve been thinking about it for a long time.
it would be great if subtilte bar on right side can be detached and manage it in a separate window like a pop up window.
I’m using LLN using multiple monitors, If this becomes possible, I think one screen can be filled with screen (also includes subtitles) and one screen can be filled with entire subtitle window, so it will be possible to use it more efficiently with a wider screen. And it will be possible to focus on the script and learn by displaying only the subtitles.
I only listed this much because I lacked creativity, but there are more.
I’d appreciate it if you could think about it.
thank you.
