Bug with ASR and Saved Subtitles (Simplified Chinese)
Hi thanks for adding the ASR feature it’s super useful!
I’ve been watching Attack on Titan in Mandarin with the use of the ASR feature. Once I hit Season 3 part 2, most of my saved subtitles are not colored.
Also if I try to mark any word, I’m prompted to set my vocabulary level, I don’t do this due because I’ve saved each word manually from scratch and don’t want to mess with my lists but this also means I can’t add mark any new words here.
The most notable difference between the prior seasons S3P2 is that the prior seasons audio language was “Mandarin”, and starting from S3P2 the audio language becomes “Mandarin (guoyu)”. Of course these are still the same language but perhaps the extension is seeing “Mandarin (guoyu)” ASR subtitles as a totally different language than Simplified Chinese? Hence the missing same words and prompt for vocab level. Included some screenshots below
Screenshots:
S3P1 Last Episode (Works perfectly with all my saved words)
S3P2 First Episode (Shows very few saved words and won’t let me save a word without setting vocab level)
Hi @woozie! I’m not sure if you still need help with this as it’s been years :sweat_smile: But I experienced the same problem, cleaning the cache and cookies for Netflix and Language Reactor helped me resolve it.
Hi @Yana I would like to report the same issue, I don’t know why it started happening but the method above worked for me.
