Apologies, if this has been asked many times before …
I am learning Swedish and there are a limited number of movies/shows in that language, so having to use the Machine Translation for subtitles. Although it works fine when I hover over a word it does show the word in Swedish, but when I click on a word to hear how it sounds, it says it in English.
Is there a way to get it connect to Google Translate or something similar so it is said in the language you are learning?
Thanks
