Hi everyone! I’m learning Spanish and would love to download Netflix subtitles to review and practice offline. Does anyone know the best way to do this? Any tools, apps, or methods that work well? I searched online and found tools like Tunelf downloader. Does it work? I want to be able to save the subtitles as text or SRT files if possible. Thanks in advance for any tips!
There is a free extension called asbplayer that can do what you’re looking for.
It has a ton of other features and is lightweight, but it makes downloading subs pretty easy.
Here’s a detailed review of Tunelf Netflix Video Downloader, and it may provide you more information about this tool. To download Netflix subtitles, you can try Language Reactor, which I’ve being using for a while now. Other than that, there are some third-party downloaders, like Tunelf, ViWizard Netflix Video Downloader. You can download them for free and try it out.
Hi! Using Netflix shows with subtitles to learn Spanish is an excellent idea, and downloading those subtitles for offline review can really help deepen your understanding and memory.
Regarding how to download Netflix subtitles, especially saving them as SRT or text files, here are a few common methods and tools:
Browser Extensions:
- This is one of the more popular methods. Several extensions for Chrome or Firefox can extract and download subtitles directly while you’re watching Netflix.
- Based on search results, extensions like “Netflix Bilingual Subtitles” ([search result 2.2], [search result 2.3]) mention the ability to download SRT subtitles, although some advanced features might require a subscription. You can search for terms like “Netflix subtitle downloader” in your browser’s web store, check reviews and feature descriptions, and choose one that suits you.
Dedicated Netflix Downloader Software:
- You mentioned Tunelf Downloader. Software like this typically claims to download Netflix videos for offline viewing. As for whether it effectively downloads subtitles, especially as separate SRT files, the search results didn’t provide direct confirmation or reviews on this specific feature. It’s best to check Tunelf’s official website for a detailed feature list or look for more specific user reviews to confirm.
In this context, I’d like to recommend Streamult Netflix Video Downloader. This tool is specifically designed for Netflix users, aiming to provide a smooth video downloading experience. According to its product information, Streamult can not only help you download HD Netflix videos but also supports saving the required audio tracks and subtitle files along with the download. Crucially, it usually offers the option to save subtitles in the easy-to-use SRT format. This makes it convenient to import both the video and subtitle files into your learning tools or text editors for offline Spanish practice. For users looking for an all-in-one solution for downloading both videos and subtitles, Streamult is a worthwhile option to consider. - Besides Streamult and Tunelf, there might be other similar download tools available. When choosing, make sure to check if they explicitly support downloading separate SRT subtitle files.
Online Subtitle Websites:
- For some popular movies and series, you might find corresponding Spanish SRT files on dedicated subtitle-sharing websites (like Subscene, OpenSubtitles, etc.). However, be aware that these subtitles might have slight differences from the Netflix version (e.g., timing or translation), and you’ll need to search for them manually.
About File Formats:
- Most dedicated download tools and browser extensions aim to allow users to save subtitles in the common SRT (.srt) format. This is a plain text format that can be opened with Notepad or any text editor and is compatible with most video players and subtitle editing software. Some tools might also support downloading as TXT (.txt) files.
Important Note:
- When using any third-party tool to download Netflix content (including subtitles), please be sure to understand and comply with Netflix’s Terms of Service and local copyright laws. These tools are generally intended for personal backup and offline viewing purposes only.
Hope this information helps you find the best method for downloading Netflix subtitles for your learning needs! Good luck with your Spanish studies!
why dont’s use StreamUlt Netflix Video Downloader to download the subtitles of video on Netflix. it’s easy to use.
i use StreamUlt Netflix Video Downloader to download the subtitles of movie of Netflix.
Hi! For downloading Netflix subtitles to practice Spanish, I highly recommend FlixiCam.
It’s a great tool that lets you:
Download videos and save subtitles separately as .srt or .vtt files.
Preserve multiple language tracks (perfect for switching between Spanish audio and English subs).
It’s works on both Windows and Mac. Just remember to use it for personal study! Happy learning! ![]()
For Netflix, this is not so simple: officially they do not allow subtitles to be downloaded normally separately from the video, and most “downloader” tools are either unstable or violate the rules of the service.
