I hope you can forgive this likely really dumb question. I cannot figure out how to set the non-native language. Can you please provide more info than that is provided in the current help info?
Thanks,
Kem LoMonaco
Thanks,
Kem LoMonaco
Hello.
In Netflix, you can change the audio langauge and the language of the primary subtitles in the Netflix menu, here:
Be careful, the audio and subtitles will often not match each other if they are not the original language. In Youtube, it’s also possible to change the subtitle langauge, although the subtitles available depend on the video.
