Traditional Chinese subtitles not working where original is Simplified
I think this might be a bug. Here are more details:
The settings:
  • Movie original audio language: Chinese
  • Movie original language subtitles: Chinese (Simplified)
My selection:
  • Audio: Original – Chinese
  • Subtitles: Chinese (Traditional) (originally provided by Netflix)
LLN Behaviour:
  • subtitles are not selectable
  • words are not highlighted
  • no dictionary lookup
  • just plain non-interactive subtitles
(My subscription is LLN Pro - so I should be able to see the highlights)
Expected behavior:
  • Works the same as with Simplified Chinese subtitles.
Thanks @Stiivi for your message.
What you say is a bit weird, as I can’t reproduce this bug locally (with both dev and production version). You can see below a screenshot of Big Fish Begornia (audio is simplified chinese and subtitle is trad chinese) Processing: image.png….
Maybe I can ask you, in this order :
  • to reload your browser (CTRL + R)
  • to reinstall the extension
  • if still not working, to send me the link of the movie you are watching ?
Sorry for this problem :confused:
  1. Removed old LLN and Language Reactor extensions
  2. Reinstalled Language Reactor
  3. Restarted Chrome
  4. Signed in
The issue persists.
Example track: The Rational Life
Simplified:
Traditional:
(neither highlights, neither mouse-over lookup)
EDIT: Same with the side-bar subtitle list. Simplified has highlights and traditional does not. Btw. I never used simplified before.
That is really weird. I have same problem as you for the drama you sent me. We are trying to find the cause of the problem.
Can you check with Big Fish Begonia also please ? I am expecting that it should work, but let’s be sure.
Thanks a lot for your patience, and sorry for this bug :confused:
Ok, we found the problem, some bad data were cached because of the bug of last week. Now everything should be working fine, just check it ! Sorry again !
Thanks! Works as expected.
