Words marked for learning don't show up in Saved Items
I recently started using LanguageReactor (I have a paid subscription). Marking words for learning works but the words don’t show up in Saved Items. If I see the same word in another text it is correctly marked as “for learning”.
Are you sure you have the dropdown set to the right langauge? I forget to set it right sometimes.
