Clicking on Subtitle bar starts playing
With the new update when you click on a line in the subtitle bar it starts playing the show again, which is really annoying when you want to copy post a sentence from the side bar into an SRS (like anki)
Is there a way to turn this off? If not could we possibly get an option to do that?
Cheers
I was just about to make a post asking this same thing! This has been pretty frustrating for me to use this morning so I might just have to use something else until it gets fixed tbh.
I also noticed this today, will try sort something out.
Thank you for all the hard work you put into this addon! It really is a great help for learning languages!
I came here for this reason as well.
Just pushed out a fix for this on Netflix (you should get it in ~24hrs). We’ll push a Youtube fix out shortly.
Working for me now, Thank you guys so much <3
