Saving more than two words together :
For now, the best way to save two words together is the save the entire phrase. Even. if it will be perfect to do it, the issue that can occurs is how the translation works : it’s word by word when you click on it. It’s the dictionary way. And when two words working different when they are together, it’s more like an expression that just a word. So in order to save the phrase, you can do it like that :
exporting saved words episode by episode:
You’re right, it will be nice to be able to exporting words episode by episode but it’s not possible yet. (Anyone can correct me if I’m wrong please)
saving word file (excel, anki etc.) with each episode’s title. like tv series/movies’ name _ season 1 _ ep1 :
Actually, it’s not possible to do it directly from the Language Reactor website BUT it’s very easy to do it after it :
It might looks long to do it, but if you’re doing it regularly, it doesn’t take much time. Excel it’s the easiest but with Anki you’re learning more efficiently. All have pros and cons…
Sorry for the French language in excel btw
If anyone has an other way to do it, I’m open to listen it
thanks for the reply. but i just wanted to know if it is possible directly on LR. anyway your suggestions are very helpful for me.
and one more question. i think it would be better if there is an LR for ipad or something like phrasepump for mobile or ipad app. i know anki is the case but i mean, your own app which is synchronized with LR. so, once i save words on LR, those words can be saved through that app automatically which makes it easier to review saved words more often and conveniently with mobile or ipad.
i mean the process of saving words, export to anki, saving files, and adding to anki is kind of too uncomfortable. i have to even edit the color of font. if you make your own app for this, it shortens this process very much.
So it’s been two years, and you didn’t add the feature of translating multiple words together? what have you been doing the past two years? even the ability to add an EPUB file is not there and i’m supposed to pay for a subscription? The languages doesn’t work 1. 1 .1 .1 . it works 1+2+3+4=5 a whole different number which means a whole different meaning. you really need to straighten up your priorities
I think saving multiple words together needs to be prioritised in 2026.
It’s a real pity as this makes flashcard creation very clunky. Words and expressions change meaning when atomised or taken out of context, and makes for a limited and disorganised study experience.
The current implementation for splitting texts and youtube transcripts is so choppy and inconsistent - sentences cut here, expressions split there… It would be nice if it were possible to highlight selected text and save that in a similar way to LingQ, Readlang and other platforms. What’s frustrating is that Language Reactor is so close to perfect! The youtube hover on subtitles feature is so nice.
